FREE Shipping NEXT DAY Delivery Call +44 (0)1782 393843 Shop now, pay later
AiM SmartyCam 2.1 & 2.2 GP HD Roll Cage Mount (V Bracket)
£70.00
SmartyCam GP HD Roll Cage Mount.
SmartyCam Roll Cage Mount to suit Solo 2 & Solo 2 DL.
Key Features:
  • Ball & Socket system
  • Secure roll bar mounting
  • Suitable for Solo2 & Solo 2DL
  • Free Race Studio 3 Download
  • Dual swivel
  • Securing clip
The AiM roll cage mount (V Bracket) to suit the Solo 2 & Solo 2 DL has been designed to securely mount the Solo 2 & Solo 2 DL to your bike or car.
The V bracket adjusts using a ball and socket system for optimum positioning and simply clamps to the roll bar, railing or tube.
The dual swivel joint makes viewing angle adjustment quick and easy.
The securing clip has a rubber lining to prevent slipping and any vibrations effecting the display.
This kit includes two tube clamps, 44mm & 55mm to enable you to attach the mount to different size roll bars, railings or tubes.
User Guide
Technical sheet
