SmartyCam GP HD U Bolt Mount.
SmartyCam Roll U Bolt Mount for mounting a SmartyCam GP HD Camara.
Key Features:
SmartyCam GP HD U Bolt Mount |
The AiM SmartyCam GP hd U Bolt is for mounting a SmartyCam GP HD to your bike or car. The mount is designed to mount to a roll bar, railings or tubes that have a diameter of between 0.5 - 1.5 inches. The U bolt clamp has a unique ball and socket system which has been designed to cope with the rigours of motorsport.
The kit includes a rubber insert and lock nuts for a more secure fit, a solid ball and socket system for optimum positioning, which securely attaches to any roll bar, railing or tube. |
The mount is adjustable so you can put the camera in the optimal position to capture the best track action. |
