Aim SmartyCam 2.1 + 2.2 GP HD U Bolt Mount for Motorcycle
£70
SmartyCam GP HD U Bolt Mount. SmartyCam Roll U Bolt Mount for mounting a SmartyCam GP HD Camara....
Key Features:
  • Ball & Socket system
  • Suitable for Solo 2 & Solo 2 DL
  • Solid Ball & Socket
  • Free Race Studio 3 Download
The AiM SmartyCam GP hd U Bolt is for mounting a SmartyCam GP HD to your bike or car.
The mount is designed to mount to a roll bar, railings or tubes that have a diameter of between 0.5 - 1.5 inches. The U bolt clamp has a unique ball and socket system which has been designed to cope with the rigours of motorsport.
The kit includes a rubber insert and lock nuts for a more secure fit, a solid ball and socket system for optimum positioning, which securely attaches to any roll bar, railing or tube.
The mount is adjustable so you can put the camera in the optimal position to capture the best track action.
AiM Product Video
User Guide
Technical sheet
