Aim SmartyCam Car ECU Bridge CAN RS232 – Aim Shop - Motorsport Data Loggers, Displays and Laptimers
SKU: SM-EB-CR
Availability: 49 in stock
£258.00
QTY:
Trust Badge
The Aim SmartyCam Car ECU Bridge CAN RS232 is available in two variants, the OBDII connector for immediate plug & play connection to the OBDII port of cars with stock ECUs or CAN/RS232 connection for direct installation on aftermarket ECUs.
They are compatible with Aim MXL Dash, Aim G-Dash and AimFormula steering wheels, and of course with the Aim SmartyCam HD and Aim SmartyCam GP HD racing cameras.
Aim ECU Bridge
ECU Bridge
ECU Bridge and RPM Bridge are two systems that are needed whenever engine data needs to be viewed  on a display or on a SmartyCam video (if no recording is require.
They are compatible with MXL Dash, G-Dash and Formula/GT steering wheels, and of course with the SmartyCam and SmartyCamGP.
ECU Bridge is to be used in when the Engine Control Unit transmits data by either OBDII, CAN or RS232.
ECU Bridge Connection Example
RPM Bridge Connection Example
Aim RPM Bridge Connection Example
ECU with Aim Products
ECU Bridge is available in two variants:
  • With OBDII connector, for immediate plug&play connection to the OBDII port of cars with stock ECUs
  • With CAN/RS232 connection, for direct installation on aftermarket ECUs.
Aim CAN - RS232 connection
RPM Bridge
RPM Bridge is to be used whenever the car has got no ECU (i.e. classic cars).
Aim ECU Bridge CAN  K-LINE
Technical Specification
  • Configurable ECU interface
  • CAN protocol for external modules (visors or SmartyCam HD)
  • USB port for PC communication
  • External power 8/18 V
  • Coil signal 150-400 V
  • Square wave signal 4-50 V
 ECU Bridge  ECU Bridge with connection cable (CAN/RS232 or CAN/K Line) USB cable  RPM Bridge  RPM Bridge with connection cable (loose wires) USB cable
In The Box
ECU Bridge
  • ECU Bridge with connection cable (CAN/RS232 or CAN/K Line)
  • USB cable
RPM Bridge
  • RPM Bridge with connection cable (loose wires)
  • USB cable
ECU
Stock and Racing ECU's
You can find a list of ECU's on our support site here
RPM Bridge pinout ver. 1.01
Pictures
