Aim SmartyCam External Power Harness
SKU: SM-EXP
- £40.00
- £40.00
The Aim SmartyCam GP HD 2.1 & 2.2 external power harness can be used to be connected to an external battery.
Suitable for all SmartyCam | External power cable 12V |
712 - 7 pins connector | Two free wires |
The Aim SmartyCam external power harness can be used to be connected to an external battery.
The power lead fits the SmartyCam and the two un-terminated free wires will connect to a 12V battery.
The cable length is 2m.
- SmartyCam External Power Harness
- Allows external battery connection 12V
- 712 - 7 pin male connection
- Cable length: 2m
- 1 x SmartyCam External Power Harness
The Aim SmartyCam GP HD 2.1 & 2.2 external power harness can be used to be connected to an external battery.Key Features :
The Aim SmartyCam external power harness can be used to be connected to an external battery. The power lead fits the SmartyCam and the two un-terminated free wires will connect to a 12V battery. The cable length is 2m. ![]() |
- Cable length: 2m
