SmartyCam GP HD Mini Roll Cage Mount.
The SmartyCam GP HD mini roll cage mounts are designed to fit the AiM SmartyCam GP HD Bullet Camara.
Key Features:
SmartyCam GP HD Mini Roll Cage Mount |
The mini roll cage mounts are designed to fit the AiM motorsport SmartyCam GP HD and enable it to easily be mounted to a roll bar tube. The mount is manufactured from aluminium with a black anodised finish and is designed to withstand the rigours of motorsport use.
Provides an easy method of mounting the AiM SmartyCam GP HD camera to a roll cage. The 2x jubilee clips allow for fitting to different roll cage tube diameters. Includes an aluminium clamp which the camera fits in to. Standard or extended lengths available. |
This kit includes two tube clamps, 44mm & 55mm to enable you to attach the mount to different size roll bars, railings or tubes. |
