SmartyCam Roll Bar Mount for Recording Box.
SmartyCam roll bar mount to fix SmartyCam securely to your Kart.
Key Features:
SmartyCam HD V-Type Roll Bar Bracket
The AIM SmartyCam GP HD bar mount for recording box is for mounting the SmartyCam recording box to a roll bar, railing or tubing. The roll bar mount has a unique ball and socket system which has been designed to cope with the rigours of motorsport.
Includes a rubber insert and lock nuts for a secure fit. A solid ball and socket type system for optimum positioning. Securely attaches to any roll bar, railing or tube. |
This mount will keep the recording box safe and secure and can be placed in a position clear from the driver so it doesn't get in the way. Aim Technologies are committed to supplying professional engineers quality Kart racing products. Our cables and accessories are well-engineered and designed for rigours of Motorsport. Aim Technologies racing components, are amongst the best in the industry today. |
AiM SmartyCam GP HD 2.1 + 2.2 Roll Frame Mount For Recording Box for Kart
- Handlebar bracket
- 90mm arm, clamp with base and ball
- Mounting bracket
- Washers and screws
