AiM SmartyCam GP HD 2.2 1m with 3.5 External Female Jack for Microphone
£35
Aim SmartyCam GP HD 2.2 External Microphone Cable. SmartyCam GP HD 2.2 1m with 3.5 External Female Jack...
Key Features:
  • Microphone cable
  • Free Race Studio 3 Download
  • 7 pin 712 binder
  • 3.5 External Jack for Microphone
Aim SmartyCam GP HD 2.2 Cable
The AiM SmartyCam GP HD 2.2 Jack Connection enables you to add an external microphone to your SmartyCam GP HD 2.2 Rev only.
The female 3.5mm jack is ideal if you want to connect the SmartyCam to your intercom system.
The cable is 1 metre in length and plugs directly into the recording unit 7 pin 712 binder connection labeled ECU-Mic.
Please Note: This cable is only compatible with the Rev 2.2 SmartyCam GP HD.
User Guide
Technical sheet
