Aim SmartyCam GP HD 2.2 Replacement Bullet Camera Motocross
SKU: SM-GP-C-67-R2 - XB1SGPH22B67
- £500.00
- £500.00
AiM SmartyCam GP HD 2.2 Replacement Bullet Camera
The AiM SmartyCam 2.2 GP HD replacement Bullet Camera, is a lightweight, robust replacement or spare part for your camera kit.
High quality camera | Replacement for SmartyCam 2.2 |
Compact & robust | Lens options 67°, 87°, 120° |
The AiM replacement bullet camera has been designed for motorsport and is incredibly light and robust.
The bullet camera is black anodised, billet machined small and compact enough to fit into the tightest of locations.
Ideal to have one spare at the track incase your camera gets damaged.
Provides high quality footage.
Lens Options
The replacement bullet camera is available in three lens versions.
The 67° lens for as it sees the track
The 87° lens is available to have a more ample view
The 120° lens gives an even wider view of the track and surroundings.
Please Note: This replacement Bullet Camera is for the SmartyCam 2.2 GP HD. If you need a replacement for the SmartyCam 2.1 GP HD see the Accessories Tab.
We also have have Bullet replacement front glass kits available in three different lens applications.
- Anodised black
- Billet machined
- Available in 67°, 87°, 120° lens
- 1 x Replacement Bullet Camera
- Lens option available 67°, 87°, 120°
The AiM SmartyCam 2.2 GP HD replacement Bullet Camera, is a lightweight, robust replacement or spare part for your camera kit.Key Features :
The AiM replacement bullet camera has been designed for motorsport and is incredibly light and robust.The bullet camera is black anodised, billet machined small and compact enough to fit into the tightest of locations.
Lens Options
The replacement bullet camera is available in three lens versions.The 67° lens for as it sees the track
These are some of the items that can be added to your bike for incrementing performance and data. ![]() |
- Anodised black
- Billet machined
