Aim Smartycam GP HD 84° Car Racing Bullet Camera – Aim Shop - Motorsport Data Loggers, Displays and Laptimers
SKU: SM-HD-GP-M
Availability: 25 in stock
£960.00
QTY:
Trust Badge
Aim Smartycam GP HD 84° Car Racing Bullet Camera is a professional on-board racing camera with data overlay with remote bullet-cam.
Aim SmartyCam GP HD Rev.2.1
SmartyCam GP HD has been designed for Motorsport with a single purpose. To produce great videos that include all the technical information that will help you improve your performance. SmartyCam GP HD is a very versatile racing camera system. It’s easy to install on most racing vehicles, it’s robust and reliable and has been engineered to withstand the extreme working conditions typical of all motorsport.
SmartyCam GP HD Rev. 2.1 competitive advantages
Real time data overlayed on videos
SmartyCam GP HD overlays all the data you need from different sources.
From GPS showing track map and vehicle position, as well as speed, lap and split times.
From Aim loggers connected to your ECU showing RPM, throttle, engaged gear, acceleration, temperatures, pressures and – in presence of additional sensors – also their values.
All these info will be overlayed on videos in each single point of the track. Here is just an example among the many available:
Your Software for Video Configuration and Analysis
SmartyCam HD uses Race Studio 3, the powerful software which allows to configure all details of your videos and to get plenty of fun and information out of them.
You can configure your overlays in a virtually infinite variety of modes: add your logo and the track map, and choose your graphic objects from a list of pre-determined sets with same layout or even single objects from different sets. Your videos will be truly “yours” in all details, from the data to their graphic layouts.
Race Studio 3 Configuration
Race Studio 3 Configuration views
Video Analysis
The video of a whole session, once downloaded on your PC, can now be split – with a simple click – in individual videos of each lap: so that you can simultaneously watch two of them and check where you were faster or slower. The same operation can be performed with any SmartyCam HD video recorded on the same track: you will be able to compare your best lap with your friends personal best!
Download RS3
Video Analysis
Automatic Start & Stop
You are on the starting grid, ready to sprint, your adrenaline reaching the climax: the last thing you can worry about is… switching on the camera. You have other things to worry about. SmartyCam HD Rev2 is aware of that, that is why it switches on/off automatically and starts/stops recording the same way.
Automatic On/Off Switch
SmartyCam HD can be switched on by the logger it is connected to. Switch-off is automatic, too: simply decide after what period of non-activity the camera will switch-off. Both operations can also be carried out using the keyboard, if you prefer.
Recording
Recording can also be started/stopped automatically or via keyboard. With automatic switch-on, the camera will start recording when the speed or RPM threshold is exceeded. In this case, you simply decide how long after dropping below the selected threshold the video will automatically stop.
No “wave effect” and Improved Quality with The New CMOS Sensor
Engine rumble causes vibrations, which are not a good thing for video recording. Never again will you experience that seasick “wave effect” you get when watching videos recorded by a generic camera, when the car rolls at 7000 RPM. SmartyCam HD has been designed for that environment and for those vibrations. “Wave effect” is just a memory.
The Global Shutter CMOS Sensor
Unlike generic multipurpose cameras, SmartyCam HD has been designed to avoid the problem of image distortion, thanks to the innovative Global Shutter CMOS sensor. The camera shutter captures the entire image at the same time, not “pixel by pixel” like traditional sensors. The result is that images are captured at once and are not affected by the vibrations that happen on a racing vehicle, which create the so-called “wave effect”.
Proprietary lenses designed for motorsports
Proprietary Lenses Designed for Motorsports
A lens specifically designed for Motorsports must be robust, must be able to work when the engine rolls 100 times per second, and have good resolution and brightness. But above all a lens designed for Motorsport must reduce distortion, which is a typical problem of lenses used by generic action-cameras: objects placed at ten meters’ distance look very far, making it impossible to accurately determine whether the track is straight or curved. SmartyCam HD telecentric lens with six elements reduces distortion to the minimum and will withstand track vibrations for years. Moreover the lenses with different HFOV’s allow a tailor-made framing in all kind of vehicles.
Which Lense?
The narrow 67° HFOV lens is preferred for closed-roof cars, as it “sees” the track just within the wind-screen pillars, reducing that unpleasant black frame around typical of generic camera on-board videos.
The wide 84° HFOV lens is specific for open-roof, formula car and kart use, where it is possible to have a more ample view of the track and there is no risk of black frames.
Which Lense?
The narrow HFOV lens is preferred for closed-roof cars, as it “sees” the track just within the wind-screen pillars, reducing that unpleasant black frame around typical of generic camera on-board videos.
Narrow lense
The wide HFOV lens is specific for open-roof, formula car and kart use, where it is possible to have a more ample view of the track and there is no risk of black frames.
The wide HFOV lens
Wide Colour TFT Display
The wide SmartyCam GP HD 240 x 320 pixel TFT color display makes installation and aiming very easy.
High-quality small-size video file
Other HD cameras are focused on the highest pixel number. The rproblem with this, is that their video files are far too large, taking too much memory. SmartyCam GP HD videos have the same quality as other HD cameras but their files are smaller because the H264 compression system parameters have been optimised to a perfect balance between video quality and file size.
You can choose among three video file quality levels: one-hour recording takes 4GB (high quality), 2GB (normal) or 1,5GB (low). Files are stored on SD cards: with current SD cards reaching 128GB capacity, you can record more than 30 hours of high-quality videos without changing the card.
High-quality small-size video files
Designed to withstand extreme on-track working conditions
Frail things have a bad time on track. An on-board camera designed for motorsport, must guarantee great resistance against the extreme working conditions typical of track racing and against the most adverse weather, such as: strong and prolonged vibrations, storms, continuous rain, and extreme high and low temperatures.
Now with External Microphone / Jack
SmartyCam GP HD is very flexible: you can add optional modules to fit it perfectly to your needs, like the ECU Bridge to connect it directly to the Engine Control Unit, the GPS, or the external microphone/jack.
Compact, handy and easy to install
The small bullet size (24 diam x 73.5 mm) and light weight (just 55 g) which make SmartyCam GP HD easy to install inside or outside your car/bike.
To make installation even easier, a wide range of brackets are available.
Get More Data, Win More Races
Six kits are available, depending on the HFOV lens and the harness:
Bullet cam HFOV 67° lens
SmartyCam GP HD Rev. 2.1 recording module, bullet cam connection harness – L=2mt, Mini B – USB adapter cable, battery charger, 4GB HC10 SD card, CD with software, user manual.
With CAN harness – L = 2 m X96SHG0267R21
With CAN harness – L = 4 m X96SHG0467R21
With External power harness – L = 2 m X96SHG0167R21
Bullet cam HFOV 84° lens
With CAN harness – L = 2 m X96SHG0284R21
With CAN harness – L = 4 m X96SHG0484R21
With External power harness – L = 2 m X96SHG0184R21
    Aim SmartyCam GP HD in the box
    Technical Specifications
    Video format : H.264 1280×720 pixels @ 30 fps
    Field of view : 67° or 84°
    Lens : Telecentric with 6 elements
    Supported SD card : Up to 128 GB
    Display : 2.4″ 240×320 pixels
    Accelerometer : Three-axial ± 5G
    Internal battery : Rechargeable Lithium battery – 1.040 mAh
    Battery charge : 700 mAh 12 V
    Internal battery duration : 60 – 70 min of recording
    External power : 9-15 V
    Auto Power ON/OFF : Yes, if connected to an AiM logger
    Auto Power OFF : Yes
    Auto Start/Stop Recording : Yes
    Usage temperatures : -10°C/+60°C
    Body : Anodized Aluminum
    Bullet cable length : 0.5 – 1.0 – 1.5 – 2.0 m
    Dimensions : Main box 102.5×65.2×26.5 mm
    Bullet camera 24 diam x 73.5 mm
    Weight : Main box 260 g, Bullet camera 55 g
    Waterproof : IP67
    GP HD Technical drawing Aim Smartycam GP HD 84 Deg Car Racing Bullet CameraAim Smartycam GP HD 84 Deg Car Racing Bullet CameraAim Smartycam GP HD 84 Deg Car Racing Bullet Camera
    Accessories
    Spare Parts
    Glass Replacement Kit X98KVOCHD0 (the kit includes the Schott B270 glass and his o-ring OR30X1)
    Display Glass Replacement kit X98KVDCHD0  (methacrylate anti-glare anti-scratch protection)
    See all Smartycam Spares
