Skip to product information
1 of 2
Aim SmartyCam GP HD Bullet Cam Roll Cage Mount
SKU: SM-VB-GP
£80.00
£80.00
Aim SmartyCam  GP HD Roll Cage Mount 2.1 & 2.2 & 3
The SmartyCam  GP HD 2.1 & 2.2 & 3 (Bullet Camera) roll cage mount has been designed to hold and position the bullet camera.
Fits the SmartyCam GP HD camera Ball & socket adjustment system
Clamp to a wide range of diameter tubing For SmartyCam GP HD 2.1 & 2.2 & 3
The Aim SmartyCam GP HD 2.1 & 2.2 & 3 roll cage mount has been designed to securely mount the SmartyCam GP HD 2.1 & 2.2 & 3 bullet camera.
Roll Cage Mount
With Race Studio 3, you can also analyse all data recorded and downloaded to your PC: graphs, histograms and tables will help you study your performance, providing an objective support to avoid mistakes and improve performances.
  • For use with SmartyCam GP HD 2.1 & 2.2 & 3
  • Handlebar bracket
  • 60mm arm
  • Ball head
  • Bullet cam bracket
Technical sheet Race Studio 3
The Aim SmartyCam GP HD 2.1 & 2.2 & 3 roll cage mount has been designed to securely mount the SmartyCam GP HD 2.1 & 2.2 & 3 bullet camera. The roll cage bracket (v-bracket) adjusts using a ball and socket system for optimum positioning and simply clamps to roll bars of a wide range of diameters. The 44mm & 55mm tube clamps enable you to attach the mount to different sized roll bars.
Roll Cage Mount
  • Handlebar bracket
  • 60mm arm
  • Ball head
