Aim SmartyCam GP HD Rev 2.2 Dual Bullet Race Camera System
£2,185
Product code: XB1SGPH22B67L200G The Aim SmartyCam GP HD Rev 2.2 Dual Bullet Race Camera System comprises of an Aim...
The Aim SmartyCam GP HD Rev 2.2 Dual Bullet Race Camera System comprises of an Aim GP HD with two Bullet Cameras and a Solo 2 DL Data logger. There are four connection options to choose from for the Solo 2 DL.
Solo 2 DL Connection Options:
  • Solo 2 DL OBDII Cable + Camera System
  • Solo 2 DL RPM Cable + Camera System
  • Solo 2 DL CAN(Ecu) Cable + Camera System
  • Solo 2 DL External Power Cable + Camera System
Key Points
  • Two HD Cameras
  • Built in GPS For Data Logging
  • Full HD Video 1280P @ 30 Fps & Audio Recording
  • Fully Configurable OLED Display Lap Timmer
  • Predictive Lap timing
  • Multiple channels displayed On Display
  • Real Time High-Definition Graphic Overlay On Video
  • Configurable LED Alarms for RPM or Split Timing
  • CAN, RPM, OBD11 or External Power Connection
  • Microphone
  • SD Card
  • Internal Power Back Up for Reliable Recording
  • Camera preview over WIFI and on Recorder Box
  • WIFI Connectivity
  • Data Analysis Software
  • 2 Roll Cage Camera Mounts
The Aim SmartyCam GP HD Rev 2.2 Dual Bullet Race Camera System  has been designed for Motorsports with a single purpose, providing great videos that include all the technical information that will help you improve your performance. All this in the most robust and reliable system ever.
Solo 2 DL Combined with SmartyCam GP HD 2.2
The Ultimate HD Bullet Cam Racing System
Aim Dual GPHD Bullet Race Camera System
Aim Smartycam GP HD Rev 2.2 has been designed for Motorsport with a single purpose. To produce great videos that include all the technical information that will help you improve your performance.
Smartycam GP HD is a very versatile racing camera system. Easy to install on most racing vehicles, it’s robust and reliable and has been engineered to withstand the extreme working conditions typical of all motorsports.
SmartyCam GP HD Rev. 2.2 competitive advantages
Real time data overlayed on videos
SmartyCam GP HD overlays all the data you need from different sources.
From GPS showing track map and vehicle position, as well as speed, lap and split times.
From Aim loggers connected to your ECU showing RPM, throttle, engaged gear, acceleration, temperatures, pressures and – in presence of additional sensors – also their values.
All these info will be overlaid on videos in each single point of the track. Here is just an example among the many available:
Race Studio 3 - Your Software for Video Configuration and Analysis
Aim SmartyCam GP HD Rev.2.2 uses Race Studio 3, the powerful software which allows to configure all details of your videos and to get plenty of fun and information out of them.
You can configure your overlays in a virtually infinite variety of modes. You can add your logo and the track map, and choose your graphic objects from a list of pre -determined sets with same layout or even single objects from different sets. Your videos will be unique in all details, from the data to their graphic layouts.
Race Studio 3 Configuration
Race Studio 3 Configuration views
Video Analysis
The video of a whole session, once downloaded on your PC, can now be split – with a simple click – in individual videos of each lap, so that you can simultaneously watch two of them and check where you were faster or slower. The same operation can be performed with any SmartyCam HD video recorded on the same track, you will be able to compare your best lap with your friends personal best!
Video Analysis
Direct CAN ECU connection
The new SmartyCam GP HD has been designed integrating the direct connection to the CAN-bus line of the ECU and it will allow to use the can-bus communication protocols included in our official database, or manage the customised can-bus protocols.
This new feature has been designed particularly for those vehicle like Formula cars or race bikes, where the available space is minimal.
Integrated Aim CAN-bus Hub
SmartyCam GP HD has now 4 connectors, one completely dedicated to the bullet cam, one for the ECU-MIC, one for the GPS08 Module connection and an extra one you can use to add an expansion you might have need.
Integrated AiM CAN-bus Hub
Automatic Start & Stop
You are on the starting grid ready to sprint, your adrenaline level at it's peak, the last thing you need to worry about, is switching on the camera. SmartyCam HD Rev2 is aware of that, that is why it switches on/off automatically and starts/stops recording the same way.
Automatic On/Off Switch
SmartyCam HD can be switched on by the logger it is connected to. Switch-off is automatic, simply decide after what period of non-activity the camera will switch-off. Both operations can also be carried out using the keyboard, if you prefer.
Recording
Recording can be started and stopped automatically or via keyboard. With automatic switch-on, the camera will start recording when the speed or RPM threshold is exceeded. In this case, you simply decide how long after dropping below the selected threshold the video will automatically stop.
No “wave effect” and Improved Quality CMOS Sensor
Engine rumble causes vibrations, which are not a good thing for video recording. Never again will you experience that seasick “wave effect” you get when watching videos recorded by a generic camera, when the car rolls at 7000 RPM. SmartyCam GP HD has been designed to eliminate this problem and give you solid clear images.
No “wave effect” and Improved Quality with The New CMOS Sensor
The Global Shutter CMOS sensor
The Global Shutter CMOS Sensor
Unlike generic multipurpose cameras, SmartyCam HD has been designed to avoid the problem of image distortion, thanks to the innovative Global Shutter CMOS sensor. The camera shutter captures the entire image at the same time, not “pixel by pixel” like traditional sensors. The result is that images are captured at once and are not affected by the vibrations that happen on a racing vehicle, which create the so-called “wave effect”.
Proprietary Lenses Designed for Motorsports
Generic action cameras are designed to record videos in many different situations, such as skiing or surfing, but in Motorsports they tend to record misleading videos. Those cameras straighten out the view ahead when on track, the corners simply disappear.
So, when you wish to check your track performance, those videos are useless, because the images are distorted. Being a camera dedicated to Motorsports, SmartyCam GP HD features lenses specifically designed to avoid distortion.
The camera is available in two versions:
The narrow HFOV lens is preferred for closed-roof cars, as it “sees” the track just within the wind-screen pillars, reducing that unpleasant black frame around typical of generic camera on-board videos.
Narrow lense
The wide HFOV lens is specific for open-roof, formula car and kart use, where it is possible to have a more ample view of the track and there is no risk of black frames.
The wide HFOV lens
Wide Colour TFT Display
The wide SmartyCam GP HD 240 x 320 pixel TFT colour display makes installation and aiming very easy.
High-quality small-size video file
Other HD cameras are focused on the highest pixel number. The problem with this, is that their video files are far too large, taking too much memory. SmartyCam GP HD videos have the same quality as other HD cameras but their files are smaller because the H264 compression system parameters have been optimised to a perfect balance between video quality and file size.
You can choose among three video file quality levels: one-hour recording takes 4GB (high quality), 2GB (normal) or 1,5GB (low). Files are stored on SD cards: with current SD cards reaching 128GB capacity, you can record more than 30 hours of high-quality videos without changing the card. (SD Cards are not included in the kit)
Aim SmartyCam GP HD side view
Designed to withstand extreme on-track working conditions
Frail things have a bad time on track. An on-board camera designed for Motorsport, must guarantee great resistance against the extreme working conditions typical of track racing and against the most adverse weather, such as: strong and prolonged vibrations, storms, continuous rain, and extreme high and low temperatures.
 Compact, handy and easy to install
The small bullet size (24 diam x 73.5 mm) and light weight (just 55 g) which make SmartyCam GP HD easy to install inside or outside your car. To make installation even easier, a wide range of brackets are available.
Get More Data, Win More Races
    Video format: H.264 1280x720 pixels @ 30 fps
    Display resolution: 2.4" 240x320 pixels
    Lens: Telecentric with 6 elements
    Field of view: 67° or 84°
    Internal battery: Rechargeable Lithium battery - 1,500 mAh
    Battery charge : 700 mAh 12 V
    Internal battery duration: 60 - 70 min of recording
    External power: 9-15 V
    Supported SD card: Up to 128 GB
    Memory capability:
    • 1.5 GB (1 hour low quality recording)
    • 2 GB (1 hour medium quality recording)
    • 4 GB (1 hour high quality recording)
    Accelerometer: Three-axial ± 5G
    Usage temperatures: -10°C/+60°C
    Auto Power ON: Yes, if connected to an AiM logger
    Auto Power OFF: Yes
    Auto Start/Stop Recording: Yes
    Body: Anodized Aluminum
    Dimensions:
    • Main unit 104.6 x 79.6 x 26.6 mm
    • Bullet camera 24 diam x 48.2 mm
    Connectors: 3 Binder 712 female connectors + 1SMA female connector
    Bullet cable length: 2.0 m
    Weight: Main unit 320 g, Bullet camera 45 g
    Waterproof: IP67
    Aim Smartycam GP HD Technical
    Glass Replacement Kit X98KVOCHD0 (the kit includes the Schott B270 glass and his o-ring OR30X1)
    Display Glass Replacement kit X98KVDCHD0  (methacrylate anti-glare anti-scratch protection)
    See all Smartycam Spares
