SmartyCam HD Roll Cage Mount.
SmartyCam V-type roll bar bracket.
Key Features:
SmartyCam HD V-Type Roll Bar Bracket
The SmartyCam V-Type roll bar bracket has been designed to securely mount the AiM SmartyCam HD Camera. The V-Bracket adjusts using a ball and socket type system for optimum positioning and simply clamps to roll bars of a wide range of diameters. |
SmartyCam HD Roll Cage Mount for 1 to 2.1 inches bar
- 1 Handlebar bracket + straps
- 160mm single ball arm
- 1 Ball head
- 1 Washer diameter 17.7mm, thickness 1.5mm, hole 6mm
