£475
GPS Lap Timer & Data Logger  AiM Solo 2 DL is the most precise and simple way to get...
AiM Solo 2 DL is the most precise and simple way to get lap times, with ECU data you can overlay it all with your SmartyCam video.
Key Feature
  • Connectable to every ECU for receiving and recording Data
  • 10 configurable RGB LEDs for simple Time +/- reference
  • Rechargeable Internal Battery
  • Multiple use Modes: Speed, Times & Performance
  • WIFI with Security for Downloading data
  • Internal 4 GB memory
  • Automatic GPS Lap Timer
  • Simple New open or Closed Track Creation
  • Configurable Delta and split times
  • Multiple & configurable Backlit Graphical Display
  • Database with more than 4,000 tracks worldwide
  • Freely Configurable Display
  • Automatic Track Recognition and start / stop
  • FREE Race Studio 3 Download
Solo 2 DL with ECU Connection
Solo 2 DL raises the bar for GPS lap timers. The unit is capable of being connected to the vehicles ECU in order to obtain various data from the sensors fitted to the car. A comprehensive range of compatible ECUs allows for an easy installation. However, in the unlikely event your particular ECU protocol is not supported, an ECU Driver Builder is available as part of the powerful Race Studio 3 Software.
The GPS technology used in this unit has been updated and now receives the data from three satellite constellations, GPS, Glonass and Galileo; making for a significant improvement in data speed and positioning precision. This means that the start up time is reduced to a matter of seconds and lap times are accurate to a tolerance of two hundredths of a second.
Coil RPM Input
Solo 2 DL now also features a digital input, allowing you to log RPM either from square wave signals (8-50V each signal) or a pulse signals (150-450v) ignition coil trigger-primary circuit.
Multiple Configurations Management
Solo 2 DL can receive up to 10 configurations at one time allowing you to switch among them through keys.
Powering on requires only a few seconds and lap times are calculated with a max 2/100 sec of tolerance.
Solo 2 DL gives instant Speed, Timing, Splits live data and predictive lap times.
Solo 2 DL screen can be back lit in one of the seven available colours:
The AiM Solo 2 DL has 10 configurable RGB LEDs, and will give you a clear and fast indication of the comparison with your last lap. Predictive page: shows the predicted current lap time in the format you set.
+/- in relation to the Reference Lap Predicted Lap Time
You can custom build the layout of the display, to show the information you choose on 4 reconfigurable pages, your data shown in your way, see an example below.
Solo 2 DL Data Recall Modes
Solo 2 DL can manage two types of data or races:
In each of these configurations, Solo 2 DL gives the complete information during the test, with the data ready to view on the Solo 2 DL or Race Studio Analysis software, immediately after each race or test session.
Data Recall on Screen Data
At the end of your test, you can quickly review all the key information on your display, RPM, Temps Times ECT.
Make it even better and add Multiple cameras to your Solo 2 DL
Wi-Fi Communication with the PC
With wifi connectivity you can transfer your data securely and quickly to your laptop or computer without cables.
Solo 2 DL New Track Creation and our Track Database
Making use of GPS technology, the Solo 2 DL is pre-loaded with a database of over 4,000 tracks from all over the world so that as soon as the unit is switched on, it identifies its position and loads the start line coordinates ready to begin recording lap times. If, however, the particular track that you are at is not recognised, the Solo 2 DL automatically enters auto-learning mode and begins to build the track layout based on your car position and records the lap times.
Unlock your potential
  • Display: Graphical
  • Display Resolution: 238x99 pixels
  • Back Light: 7 configurable RGB colours
  • Shift Lights/alarm LEDs: 10 configurable RGB LEDs
  • Inertial Platform: Internal 3 axis ±5G accelerometer + 3 axis gyro + 3 axis magnetometer
  • Wi-Fi Connection: Yes
  • GPS: 10 Hz External power: 12 V
  • Memory: 4 GB
  • Battery Type: Rechargeable Lithium
  • Pushbuttons: Metallic
  • Dimensions: 98.0x73.7x30.2 mm
  • Weight: 240 g, battery included
  • ECU Connection: CAN,RS232 or K-Line to 1,000 + industry leading ECUs
  • Multiple Configuration Management: Yes
Search compatible ECU's by manufacturer supported by AiM
Click here >
Solo 2 DL 360° Product View
  • Aim Solo 2 DL
  • Power Cable with AC adapter
  • Mounting Bracket with screws
  • User Manual
  • Aim Sticker
Choice of cables:
  • CAN/K-Line/External power cable with OBDII connector
  • CAN/RS232 external power cable
  • RPM/External power cable (if your vehicle has no ECU)
