GPS Lap Timer & Data Logger
AiM Solo 2 DL the most precise and simple way to get lap times, with ECU data and overlay it all with your SmartyCam video as well.
Key Features:
Solo 2 DL now also features a digital input allowing you to log RPM either from square wave signals (8-50V each signal) or a pulse signals (150-450v) ignition coli trigger-primary circuit. |
Powering on requires only a few seconds and lap times are calculated with a max 2/100 sec of tolerance. Solo 2 DL gives instant Speed, Timing, Splits live data and predictive lap times.
The AiM Solo 2 DL has 10 configurable RGB LEDs and will give you a clear and fast indication of the comparison with your last lap. Predictive page: shows the predicted current lap time in the format you set. +/- in relation to the Reference Lap Predicted Lap Time You can custom build the layout of the display to show the information you choose on 4 reconfigurable pages your data shown in your way see an example below. |
Solo 2 DL Data Recall Modes
The SmartyCam HD 2.1 has been designed for motorsports with the purpose of providing great videos that will include all your technical information that will help you improve your driving performance. Get overlays for all your data from GPS i.e ROM, engaged gear, acceleration, temperatures, pressures. All of this information will be overplayed on videos in each single point of the track. The Data Hub is a CAN connection multiplier that works as an interface between all of our AiM loggers. The Data Hub takes all your information to the logger with only one cable. |
Wi-Fi Communication with the PC
Making use of GPS technology, the Solo 2 DL is pre-loaded with a database of over 4,000 tracks from all over the world so that as soon as the unit is switched on, it identifies its position and loads the start line coordinates ready to begin recording lap times. If, however, the particular track that you are at is not recognised, the Solo 2 DL automatically enters auto-learning mode and begins to build the track layout based on your car position and records the lap times. |
Solo 2 DL Lap Timer
- Display: Graphical
- Display Resolution: 238x99 pixels
- Back Light: 7 configurable RGB colours
- Shift Lights / alarm LEDs: 10 configurable RGB LEDs
- Integrated Track Database: Yes
- Internal Platform: Internal 3 axis + 5G accelerometer + 3 axis gyro + 3 axis magnetometer
- Wi-Fi Connection: Yes
- GPS: 10 Hz External power: 12V
- Memory: 4 GB
- Battery Type: Rechargeable Lithium
- Dimensions: 98.0 x 73.7 x 30.2mm
- Weight: 240g, battery included
- ECU Connection: CAN RS232, or K-Line to 1,000 + industry leading ECUs
- Multiple Configuration Management: Yes
- Aim Solo 2 DL
- Power Cable with AC adapter
- Mounting Bracket with screws
- User Manual
- Aim Sticker
- CAN/K-Line/External power cable with OBDII connector
- RPM/External power cable (if your vehicle has no ECU)
SmartyCam HD 2.1
- 2X SmartyCam HD 2.1
- Battery Charger
- 2X USB/AC power adapter
- 2 CAN Hub
- AiM sticker
