AiM Solo 2 DL with Plug & Play kit for Get GP1 Evo & Get Power is the most precise way to get lap times.
Key Features:
Solo 2 DL raises the bar for GPS lap timers. The unit is capable of being connected to the vehicles ECU in order to obtain various data from the sensors fitted to the car. A comprehensive range of compatible ECUs allows for an easy installation. However, in the unlikely event your particular ECU protocol is not supported, an ECU Driver Builder is available as part of the powerful Race Studio 3 Software. |
Solo 2 DL now features a digital input allowing to log RPM either from square wave signals (8-50V each signal) or pulse signals (150-450v) ignition coli trigger-primary circuit. |
Solo 2 DL gives instant Speed, Timing, Splits live data and predictive lap times.
Solo 2 DL screen can be back lit in one of seven available colours
The Solo 2 DL has 10 configurable RGB LEDs, and will give you a clear and fast indication of the comparison with your last lap. Predictive page: shows the predicted current lap time in the format you set. |
Solo 2 DL can manage two types of data or races: |
The perfect connection to get all your data from the ECU merge them with the GPS information and transmit everything to the SmartyCam HD then watch the graphical overlay in the video.
Make it even better and add Multiple cameras to your Solo 2 DL
With wifi connectivity you can transfer your data securely and quickly to your laptop or computer without cables. |
- Display - Graphical
- Display resolution - 238x00 pixels
- Display pages - Up to 5 freely configurable
- Back light - 7 configurable RGB colours
- Shift lights / alarm LEDs - 10 configurable RGB LEDs
- Intertial platform - Internal 3 axis +5G accelerometer + 3 axis gyro + 3 axis magnetometer
- Wi-Fi connection - Yes
- GPS - 10Hz
- External power - 12 V
- Memory - 4 GB
- Battery type - Rechargeable Lithium
- Push buttons - Metallic
- Dimensions - 98.0x73.7x30.2 mm
- Weight - 240g battery included
- Waterproof - IP67
ECU connection - CAN, RS232 or K-Line to 1,000+ industry leading
- Aim Solo DL 2 Motorcycle Lap Timer
- Power cable with AC adapter
- User manual
- Aim sticker
- Get GP1 EVO + GET Power ECU
