Aim Solo 2 DL Motocross Plug & Play Lap Timer Kit Honda CRF 250cc
£500
Predictive Lap Timer & Data Logger  AiM Solo 2 DL with Plug & Play kit for Honda CRF the...
AiM Solo 2 DL with Plug & Play kit for Honda CRF the most precise way to get lap times.
Key Features:
  • Direct ECU data logging
  • 10 configurable RGB LEDs for simple Time +/- reference
  • Rechargeable internal battery
  • WiFi with security for downloading data
  • Automatic GPS lap timer
  • Configurable delta & split times
  • Database with more than 4,000 tracks worldwide
  • Freely configurable display
  • Automatic track recognition
  • Free race studio 3download
Honda Plug & Play Kit
Connect the Solo 2 DL to your Honda ECU and get all the engine performance information you need.
This Kit is compatible with the following Honda bike models:
  • Honda CRF - 250 cc from 2010 onwards
  • Honda CRF - 450 cc from  2009 onwards
     The Solo 2 DL with ECU Connection
    Solo 2 DL raises the bar for GPS lap timers. The unit is capable of being connected to the vehicles ECU in order to obtain various data from the sensors fitted to the car. A comprehensive range of compatible ECUs allows for an easy installation. However, in the unlikely event your particular ECU protocol is not supported, an ECU Driver Builder is available as part of the powerful Race Studio 3 Software.
    The GPS technology used in this unit has been updated and now receives the data from three satellite constellations, GPS, Glonass and Galileo, making for a significant improvement in data speed and positioning precision. This means that the start up time is reduced to a matter of seconds and lap times are accurate to a tolerance of two hundredths of a second.
    Coil RPM Input
    Solo 2 DL now features a digital input allowing to log RPM either from square wave signals (8-50V each signal) or pulse signals (150-450v) ignition coli trigger-primary circuit.
    The power ON requires only a few seconds and lap times calculated with a max 2/100 sec of tolerance.
    Solo 2 DL gives instant Speed, Timing, Splits live data and predictive lap times.
    Solo 2 DL screen can be back lit in one of seven available colours
    The Solo 2 DL has 10 configurable RGB LEDs, and will give you a clear and fast indication of the comparison with your last lap. Predictive page: shows the predicted current lap time in the format you set.
    +/- in relation to the Reference Lap Predicted Lap Time.
    You can custom build the layout of the display to show the information you choose on 4 reconfigurable pages your data shown in your way see an example below.
    Solo 2 DL Data Recall Modes
    Solo 2 DL can manage two types of data or races:
    In each of these configurations, Solo 2 DL gives the complete information during the test, with the data ready to view on the Solo 2 DL or Race Studio 3 Analysis software immediately after each race or test session.
    Data Recall on Screen Data
    At the end of your test you can quickly review all the key information on your display, RPM, Temps Times ECT.
    SmartyCam HD or HD GP Connection
    The perfect connection to get all your data from the ECU merge them with the GPS information and transmit everything to the SmartyCam HD then watch the graphical overlay in the video.
    Make it even better and add Multiple cameras to your Solo 2 DL
    Wi-Fi Communication with the PC
    With wifi connectivity you can transfer your data securely and quickly to your laptop or computer without cables.
    Solo 2 DL New Track Creation and our Track Database
    Making use of GPS technology, the Solo 2 DL is pre-loaded with a database of over 4,000 tracks from all over the world so that as soon as the unit is switched on, it identifies its position and loads the start line coordinates ready to begin recording lap times. If, however, the particular track that you are at is not recognised, the Solo 2 DL automatically enters auto-learning mode and begins to build the track layout based on your car position and records the lap times.
    Solo 2 DL Product Video
      • Display - Graphical
      • Display resolution - 238x00 pixels
      • Display pages - Up to 5 freely configurable
      • Back light - 7 configurable RGB colours
      • Shift lights / alarm LEDs - 10 configurable RGB LEDs
      • Integrated track database - Yes
      • Intertial platform - Internal 3 axis +5G accelerometer + 3 axis gyro + 3 axis magnetometer
      • Wi-Fi connection - Yes
      • GPS - 10Hz
      • External power - 12 V
      • Memory - 4 GB
      • Battery type - Rechargeable Lithium
      • Push buttons - Metallic
      • Dimensions - 98.0x73.7x30.2 mm
      • Weight - 240g battery included
      • Waterproof - IP67
      • ECU connection - CAN, RS232 or K-Line to 1,000+ industry leading
      Solo 2 DL 360° Product View
      • Aim Solo DL 2  Motocross Lap Timer
      • Power cable with AC adapter
      • User manual
      • Aim sticker
      • Honda CRF Cable
