Aim Solo 2 DL Motocross Plug & Play Lap Timer Kit Suzuki RMZ 250
£500
Predictive Lap Timer & Data Logger  AiM Solo 2 DL with Plug & Play kit for Suzuki the most precise...
AiM Solo 2 DL with Plug & Play kit for Suzuki the most precise way to get lap times.
Key Features:
  • Connectable to every ECU for receiving and recording Data
  • 10 configurable RGB LEDs for simple Time +/- reference
  • Rechargeable internal battery
  • Multiple use modes: speed, times & performance
  • WIFI with security for downloading data
  • Internal 4 GB memory
  • Automatic GPS lap timer
  • Simple new open or closed track creation
  • Configurable delta and split times
  • Multiple & configurable backlit graphical display
  • Database, with more than 4,000 tracks worldwide
  • Freely configurable display
  • Automatic track recognition and start / stop
  • Free Race Studio 3 Download
The Suzuki Plug & Play Kit
Connect the Solo 2 DL to your Suzuki's ECU and get all the engine performance information you need.
Whether you are on the track or the open road this data logger displays and records your engine parameters such as RPM, gear, throttle position, air temperature, speed and more.
After your race upload your data to Race Studio 3 and examine your data.
This Kit is compatible with the following Suzuki bike models:
  • Suzuki - RMZ 250 - 2010 - 2013
     The Solo 2 DL with ECU Connection
    Connecting to over 1,000+ ECUs we are sure it will work for you.
    You can connect your Solo 2 DL to the ECU with the Suzuki Plug & Play kit to provide you with all your motocross information and power with just one cable.
    Incase your ECU protocol is not in the database no problem: with our ECU Driver Builder you can build your own its free in Race Studio 3 configuration software and you will be able to create your protocol on your own.
    Coil RPM Input
    Solo 2 DL now features a digital input allowing to log RPM either from square wave signals (8-50V each signal) or pulse signals (150-450v) ignition coli trigger-primary circuit.
    Multiple Configurations Management
    Solo 2 DL can receive up to 10 configurations at one time allowing you to switch among them through keys.
    The Most Precise and Easy Way to get Lap Times
    Aim Solo 2 DL is the most precise GPS Lap Timer there is with the ability to show you your lap delta as you drive...receiving data from two satellite constellations from any where on the globe by using GPS and Glonass also giving you a significant improvement in data speed and positioning precision.
    The power ON requires only a few seconds and lap times calculated with a max 2/100 sec of tolerance.
    Solo 2 DL gives instant Speed, Timing, Splits live data and predictive lap times.
    Solo 2 DL screen can be back lit in one of seven available colours.
    The AiM Solo 2 DL has 10 configurable RGB LEDs, and will give you a clear and fast indication of the comparison with your last lap. Predictive page: shows the predicted current lap time in the format you set.
    +/- in relation to the Reference Lap Predicted Lap Time.
    You can custom build the layout of the display to show the information you choose on 4 reconfigurable pages your data shown in your way see an example below.
    Solo 2 DL Data Recall Modes
    Solo 2 DL can manage two types of data or races:
    In each of these configurations, Solo 2 DL gives the complete information during the test, with the data ready to view on the Solo 2 DL or Race Studio Analysis software immediately after each race or test session.
    Data Recall on Screen Data
    At the end of your test you can quickly review all the key information on your display, RPM, Temps Times ECT.
    SmartyCam HD or HD GP Connection
    The perfect connection to get all your data from the ECU merge them with the GPS information and transmit everything to the SmartyCam HD then watch the graphical overlay in the video.
    Make it even better and add Multiple cameras to your Solo 2 DL
    Unlock your potential with SmartyCam and Race Studio 3
    Wi-Fi Communication with the PC
    With wifi connectivity you can transfer your data securely and quickly to your laptop or computer without cables.
    Solo 2 DL New Track Creation and our Track Database
    Solo 2
     DL allows you to simply create a new temporary or permanent track layout whether it's a point to point run for rallying or a closed loop track it can simply be aded to the Solo 2 DL and PC database.
    Simply put if there is no track already the Solo 2 DL will create a new one...
    With over 4000 tracks pre-loaded from around the world. As soon as its switched on the Solo 2 DL identifies its position then once you start to drive it automatically recognises the start line coordinates of the track and will start sampling lap times every time you go past.
    If the tracks not loaded in the database
    Solo 2 DL will switch to learning mode automatically and will understand the characteristics of the track and give you your lap time.
    Our mission is to help educate you and enable you to get the most out of your AiM data equipment… whether you are new to racing or a seasoned professional there is always something new to learn.
    AiM Solo 2 DL Product Video
      • Display - Graphical
      • Display resolution - 238x00 pixels
      • Display pages - Up to 5 freely configurable
      • Back light - 7 configurable RGB colours
      • Shift lights / alarm LEDs - 10 configurable RGB LEDs
      • Integrated track database - Yes
      • Intertial platform - Internal 3 axis +5G accelerometer + 3 axis gyro + 3 axis magnetometer
      • Wi-Fi connection - Yes
      • GPS - 10Hz
      • External power - 12 V
      • Memory - 4 GB
      • Battery type - Rechargeable Lithium
      • Push buttons - Metallic
      • Dimensions - 98.0x73.7x30.2 mm
      • Weight - 240g battery included
      • Waterproof - IP67
      • ECU connection - CAN, RS232 or K-Line to 1,000+ industry leading
      AiM Solo 2 DL 360° Product View
      • Aim Solo DL 2  Motocross Lap Timer
      • Power cable with AC adapter
      • Mounting bracket with screws,
      • User manual,
      • Software installation CD,
      • Aim sticker
      • Suzuki Cable RMZ 250
