Aprilia RSV4 Bracket.
The AiM Bracket for Aprilia RSV4 is used to securely fix the AiM Solo 2 / Solo 2 DL on to your Aprilia.
Key Features:
This bracket is only compatible with RSV4 original triple clamp. |
Not Enough Check Out Our Solo 2 DL & SmartyCams |
AiM Solo 2 & Solo 2 DL Aprilia RSV4 Bracket
- 1 bracket
- 1 allen screw with rounded head M8X45mm
- 2 Allen screws with flat head M4X10mm
- 1 toothed washer
- 1 rubber dowel
