AiM Solo 2 & Solo 2 DL Honda CBR 600RR, 100RR HRC, 100RR, 1000RR HRC Bracket
SKU:
HON-B - X46KSHCBR6
£35.00
The AiM Bracket for Honda 1000RR & 600RR is used to securely fix the AiM Solo 2 / Solo 2 DL on to your Honda.
Key Features:
Our bike specific brackets provide a simple and secure mounting solution for the AiM Solo 2 & Solo 2 DL lap timer. |
Not Enough Check Out Our Solo 2 DL & SmartyCams |
Unlock your potential |
- 1 bracket
- 2 Allen screws with flat head M4X10MM
- 1 washer
- 1 Allen screw with rounded head M6x60
- 1 rubber dowel
