Suzuki GSX-R Bracket.
The AiM Bracket for Suzuki GSX-R 600, 750, 1000 is used to securely fix the AiM Solo 2 / Solo 2 DL on to your Suzuki.
Key Features:
Not Enough Check Out Our Solo 2 DL & SmartyCams |
AiM Solo 2 & Solo 2 DL Suzuki GSX-R 600, 750, 1000 Bracket (2001-2019)
- 1 bracket
- 1 Allen screw with rounded head M8x45mm
- 2 Allen screws with flat head M4x10mm
- 1 toothed washer
- 1 rubber dowel
