AiM Solo 2 & Solo 2 DL Yamaha YZF-R1/R1M (from 2015) & YZF-R6 (from 2017)
£35.00
Yamaha YZF-R1/RIM & YZF-R6 Bracket
The AiM Bracket for Yamaha YZF-R1/RIM & YZF-R6 is used to securely fix the AiM Solo 2  / Solo 2 DL on to your Yamaha.
Key Features:
  • Yamaha Bracket
  • Fits Solo 2 & Solo 2 DL
  • Includes hardware
  • Free race studio 3 download
Yamaha Solo 2 & Solo 2 DL Bracket:
  • Yamaha YZF-R1/RIM - from 2015
  • Yamaha YZF-R6 - from 2017
Our bike specific brackets provide a simple and secure mounting solution for the AiM Solo 2 & Solo 2 DL lap timer.
The brackets are supplied with all the necessary hardware required for fitting to the bike.
If you need help then please check our technical data sheet.
Not Enough Check Out Our Solo 2 DL & SmartyCams
Unlock your potential
    • 1 bracket
    • 1 rubber dowel
    • 1 Allen screw with flat head M6
    • 1 rubber washer
    • 2 Allen screws with flat head M4X10
