AiM Solo Motorcycle Backing Plate
£20
Solo Backing Plate The AiM spare backing plate to fit the Solo enables you to mount your Solo...
Solo Backing Plate
The AiM spare backing plate to fit the Solo enables you to mount your Solo to most flat surfaces.
Key Features:
  • Spare mounting bracket
  • Allows fit to additional vehicles
  • Suitable for the Solo
  • Free race studio 3 download
Our AiM spare backing plate to suit the Solo enables you to mount your Solo to most flat surfaces.
Standard original mount ideal for use as a spare.
Can be mounted onto flat surfaces.
AiM Product Video
    AiM Solo Backing Plate
    • 1 backing plate
    • 2 washers
    • 2 bolts
    • 2 screws
      User Guide
      Technical sheet
