Aim Solo 2 DL Motocross Plug & Play Dash Logger Kit Suzuki RMZ 250
£420
The Aim Solo 2 DL, Motocross ‘Plug & Play’ Dash Logger Kit is designed to fit the Suzuki RMZ 250 (2010 onward) and RMZ 450.
The kit, allows you to connect the Aim Solo DL to the bike's Engine Control Unit (ECU), a powerful data acquisition system recording important data, such as RPM, throttle position, temperatures, lambda value, etc. linked to your position on track.
All this is possible without additional sensors.
The kit includes a ECU connection lead.
Aim Solo 2 DL GPS + ECU Motocross Track Day Lap Timer Logger
Solo 2 DL Connects Straight into Your ECU
There are more than 1,000 protocols for over 1,000 ECU’s in the Aim database to allow the Solo 2 DL easy connection to your Engine Control Unit providing you a lot of information with just one cable. When your ECU protocol is not in the database, an ECU Driver Builder is always available in the Race Studio 3 configuration software which you will be able to create your protocol by yourself.
Coil RPM input
Coil RPM input Solo 2 DL now features a digital input allowing to log RPM either from square wave signals (8-50 V each signal) or pulse signals (150-450 V ignition coil trigger – primary circuit). The power ON requires only a few seconds and the lap times are calculated with a max 2/100 sec of tolerance.
Aim Solo 2 DL Back Light Screen has 7 Available Colours
Find Your Track Easily and Quickly
Solo 2 DL relies on a database of more than 3,000 tracks all over the world: as soon as it switches on, Solo 2 identifies its position, recognises the starting line coordinates of the track and starts sampling lap times.
Find your track easily and quickly
Solo 2 DL Configurable RGB LEDs
Motocross Solo 2 DL Configurable RGB LEDs
The Aim Solo 2 DL Motorcycle configurable RGB LED's, will give you a clear and fast indication of the comparison with your best lap.
Different Race Mode Selections
Solo 2 DL Motorcycle Track Day Lap Timer can manage different types of races, Speed races in a closed circuit, Point to-point races, Regularity, Performance tests (0-100 km/h etc.) In each of these configurations, Solo 2 DL Motorcycle gives you the correct information during the test and powerful data review immediately after each session.
 Solo 2 DL Race Data Recall on Screen
At the end of your session, you can quickly review all the key information on your Solo 2 DL display.
Wi-Fi Communication with the PC
Solo 2 Wi-Fi Communication with the PC
The Solo 2 DL Lap Timer / Logger Wi-Fi connection is easy and fast without connectors or cables, Simply the best way to configure your Solo 2, to manage the track database and to download the data to your PC. Use your iPhone for a quick and comfortable data analysis, for managing the track database and even for an On-Line view of the most important parameters of your Engine.
SmartyCam HD Connection
See all your ECU and GPS data in your video on sharp graphical overlay in the video.
ECU information can be found in our support centre here
  • Uses GPS Technology For Lap Times
  • Suitable For Circuit Racing, Drag Racing, Sprints & Hillclimbs
  • Logs ECU Information i.e. RPM, Temp, Pressures etc.
  • Connect to SmartCam HD Or SmartyCam HD GP
  • No External Beacon Required
  • In Built Accelerometer
  • User Selectable Screen Displays
  • Predictive Lap Timing
  • Inbuilt Track Database
  • Backlit Easy To Read Display
  • Includes Data Analysis Software
  • Display: Graphical
  • Display resolution:128x64 pixels
  • Display pages: Up to 8 freely configurable
  • Back light:7 configurable RGB colors
  • Shift lights/alarm LEDs:10 configurable RGB LEDs
  • Integrated track database:Yes
  • Inertial platform:Internal 3 axis ±5G accelerometer + 3 axis gyro + 3 axis magnetometer
  • Wi-Fi connection: Yes
  • GPS: 10 Hz External power:12 V
  • Memory: 4 GB
  • Pushbuttons: Metallic
  • Dimensions: 98.0x73.7x30.2 mm
  • Weight: 240 g, battery included
Solo DL 2  Motorcross ECU connection: CAN, RS232 or K-Line to 1,000 + industry leading ECUs
Solo 2 Front View SOLO-2-Rear-View SOLO-2-Side-View
  • Aim Solo 2 DL GPS Lap Timer
  • Ecu and power connection lead
  • User manual,
  • Software installation CD
  • AIM sticker
