SAME-DAY DISPATCH
on orders before 3pm
FINANCE AVAILABLE
on selected products
FIRST-CLASS SUPPORT
Aim Steering Angle 10 Revolutions with Bracket
£100
Steering Angle 10 Revolutions with Bracket. The steering angle sensor measures the angle of the steering wheel in degrees as the driver turns the wheel.
This is done in degrees, as, the driver turns the wheel you can see how much steering input they put in. Then, you can pick out and see where they are losing time due to steering. This could be turning too much or too little into a corner.
Aim Steering Angle Sensor
Technical Specifications:
10 revs
For 22 mm diameter steering column
  • Nominal resistance 10kohm
  • Tolerance +/- 5%
  • Precision 0.03 %
  • Mechanical travel 1800° / 5 revs
  • Temperature range - 55°c to 125°c
  • Connector 4 way binder 719 plastic
