NEXT DAY DELIVERY
on orders before 3pm
FINANCE AVAILABLE
on selected products
FIRST-CLASS SUPPORT
Aim Steering Angle Sensor With bracket
£105
The Steering Angle Sensor With bracket measures the angle of the steering wheel. This is done in degrees, as the driver turns the wheel you
The Steering Angle Sensor With bracket measures the angle of the steering wheel. This is done in degrees, as the driver turns the wheel you can see how much steering input they put in. Then you can pick out and see where they are losing time due to steering. This could be turning too much or too little into a corner.
Technical Specifications:
1 revs
For 22 mm diameter steering column
  • Nominal resistance 10kohm
  • Tolerance +/- 5%
  • Precision 0.03 %
  • Mechanical travel 360° / 1 revs
  • Temperature range - 55°c to 125°c
  • Connector 4 way binder 719 plastic
