AiM Strada IVA Vehicle Integration Loom MXS, MXP, MXG
SKU:
MX-S-VIL - MX-S-VIL
£145.00
Strada Integration Loom.
AiM Pre-wired Strada Integration Loom.
Key Features:
The AiM Strada Vehicle Integration Loom allows you to connect all your lights and the included speed sensor to your dash in the simplest possible way. The loom has a 23 pin plug the plugs into the rear of an MXS, MXP, MXG Strada ( MX Series). With each wire in the harness colour coded so when connecting it to your vehicle you just have to follow the wiring diagram for an easy installation.
Made from high quality professional cables. |
