Aim Strain Gauge Amplifier - SGAMP – AimShop.com
SKU: SGAMP
Availability: 30 in stock
£185.00
QTY:
Trust Badge
Technologies 24-Bit ADC-to-CAN Amplifier is designed to measure the voltage signal from a strain gauge or load cell with class-leading precision & ultra-low noise, and outputs the raw voltage, temperature, and user-calibrated output with advanced temperature compensation via CAN. The amplifier measure’s differential voltages with a resolution of 1μV and RMS noise of only ±750nV at a sampling frequency of 100Hz. The differential voltage and temperature is broadcasted via CAN but it may also be programmed to simultaneously transmit a calibrated output (convert voltage to strain/force) with linear or advanced tabular temperature compensation.
AMPLIFIER SPECIFICATIONS
  • Differential Voltage Measurement Range, ΔV ±7.8 mV (limited by 16-bit CAN output)
  • Maximum Differential Voltage, ΔVmax ±5.0 V
  • Resolution 1 μV (limited by 16-bit CAN output)
  • Accuracy ±60 μV
  • RMS Noise : ±6 μV at 830Hz ±750 nV at 100Hz ±500 nV at 50Hz ±200 nV at 8Hz
(For 350Ω full-bridge strain gauge / load cell with excitation) ±6 μV at 830Hz ±750 nV at 100Hz ±500 nV at 50Hz ±200 nV at 8Hz
  • Filter 1st Order Low-Pass Filter, fc = 1.6kHz
  • Supply Voltage, Vs 5 to 8 V
  • Supply Current, Is (typ) 34 mA
  • Bridge Excitation Voltage, VB 4 V
  • Maximum Bridge Excitation Current Draw, IB.max 40 mA
  • Input Impedance, RI 110 kΩ
  • Recommended Strain Gauge / Load Cell Impedance, RB 350 Ω
  • Resolution, Temperature Sensor 0.4˚C
  • Accuracy, Temperature Sensor ±2.0˚C
MECHANICAL SPECIFICATIONS
  • Weight (including wiring harness) 10 g L x W x H (max),
  • Amplifier 38 x 20 x 5 mm
  • Protection Rating IP66
  • Package Temperature Range, Tp -40 to 85˚C
