The Aim TC Hub Thermocouple Multiplier allows for up to four additional thermocouples to be connected to monitor all temperatures via CAN to Aim dataloggers.
Using more TC Hub you can easily keep under control all your temperature sensors data, monitoring each single cylinder exhaust gas temperature, together with water, oil and head temperatures.
The Aim TC Hub - Thermocouple Multiplier is waterproof and robust thanks to its aluminum structure, TC Hub provides reliable data as its sampling frequency is configurable up to 50Hz per channel. Finally, with TC Hub your wiring overall is reduced to the minimum.
