MyChron4 & MyChron5 Thermocouple
Our AiM K type thermocouple temperature sensor.
Key Features:
Temperature Sensor |
The AiM K type thermocouple temperature sensor are professional made to a high standard and are fitted with an easy to use 2 pin male thermocouple connection. |
High quality sensor that will give you the most accurate readings. Designed for rigours Motorsport. 2 pin K type thermocouple male connector. |
The thermocouple 1.5m patch lead is used to connect an AiM thermocouple such as the EGT (exhaust gas temperature) or a CHT (cylinder head temperature) to an AiM TC Hub or directly to a MyChron4 0r MyChron5 lap timer / dash logger. |
712 3 pin metal binder plug to Thermocouple yellow |
AiM Cylinder Head Thermocouple 14mm for MyChron4 & MyChron5 & Patch Lead
- Temperature working range: 0-300°C (32-572°F)
- Cable type: Compensated
- AiM Thermocouple Temperature Sensor 14mm
- 1.5m Patch Lead 3 pin 712 male connector
