Tyre Pressure Monitoring System
Whether you're an engineer looking to understand your race car's tyre behaviour, or an OEM looking for a TPMS to meet legislative requirements. We have the system for you.
Key Features:
Add a TPMS Handset to clone your extra sensors |
You can add a Handset to your kit. The TPMS handset is used for direct reading of sensor parameters such as pressure, temperature and battery voltage. It can also be used to program or modify the sensor parameters, team code and wheel location. The hand set is a valuable tool for recognising any changes to new sensor positions when swapping wheels and updating the receiver accordingly. |
TPMS Connections
Unlock your potential |
Our mission is to help enable you to get the most out of your AiM data equipment… whether you are new to racing or a seasoned professional, there is always something new to learn. |
Sensors
- Lightweight: 20g
- Pressure Resolution: 15.7Mbar
- 2Hz update
- Sensor pressure measurement range: 0-8000mbar
- High frequency modulation mode: FSK
- Sensor temperature measurement range: -40°C to 125°C
- Sensor temperature resolution: 1°C
- Sealing: IP67
- Battery lifespan: >2.5 Million transmissions
- RF frequency: 433.92MHz
- High frequency emission power: <8dbm (50ohms)
Receiver & Harness
- 1 Mbit CAN Interface
- Lightweight
- 4 unique Sensor codes
- Individual CAN ID's for corner positions
- Automatic learning for sensor serial number
- Cable length: 300mm
- Connector: AMP Superseal 6 way socket
- Mating connector: AMP Superseal 6 way plug
Pinout for receiver
- PIN 1 RED - Supply 9-16V
- PIN 2 WHITE - Screen
- PIN 3 BLACK - GND
- PIN 4 GREEN - CAN-
- PIN 5 YELLOW - CAN+
- PIN 6 N/C
- 4,8,12 Sensors depending on which chosen at checkout
- 1 TPMS Receiver
- 1 Wiring Harness
