Aim Tyre Pressure Sensor V2 – AimShop.com
SKU: TPMS_V2
Availability: 30 in stock
£275.00
QTY:
Trust Badge
Aim Tyre Pressure Sensor v2
Aim Technologies wireless Tyre Temperature and Pressure Monitoring System (TTPMS) consists of small, lightweight, wheel-mounted sensors and an equally small receiver with a built in pressure transducer for high-accuracy gauge pressure measurements.
The wireless sensor measures Tyre pressure with a high-resolution 24-bit pressure transducer, providing invaluable tyre data for Motorsport and R&D applications.
SPECIFICATIONS – TTPMS SENSOR
  • Pressure, Range (Gauge) 0 to 5000 mBar
  • Pressure, Resolution 1 mBar
  • Pressure, FS Accuracy (typ) ±10 mBar
  • Internal Temperature, Range -40 to 150˚C
  • Internal Temperature, Resolution 0.1˚C
  • Internal Temperature, FS Accuracy ±1.0˚C
  • Sampling Period at Speed 1 second
  • Operating Temperature Range* 0 to 135˚C
  • Battery Life (typ) 1.5 million transmissions
  • Encryption AES-128
  • RF Frequency 868, 915, 920 MHz
  • RF Output Power 1mW
  • Wireless Range, Open Space > 100m
*Will survive brief temperature excursions < 150˚C
MECHANICAL SPECS – SENSOR
  • Weight 21 ± 1g
  • Material 7075-T6 Max.
  • Centrifugal Accel. 2000G (SF = 3)
  • L x W x H (max) 44 x 32 x 18 mm
  • Protection Rating IP61
