AiM Water / Oil PT100 Thermo Resistor M10 Thread Motorcycle
£65.00
AiM Water / Oil Thermal Resistor
Our Water / Oil PT100 thermo resistor sensor can measure and sample temperature.
Key Features:
  • Temperature Sensor
  • 4 pin
  • Free race studio 3 download
  • M10 Thread
Measure Water / Oil Temperature
The thermo resistor must be placed in the cooling system / oil sump.
Install the sensor away from heat and electromagnetic interference sources, such as RPM cable or lap timer receiver cables.
Professional quality AiM analogue sensors fitted with male 4 pin black 719 binder plug connections, to suit all AiM loggers and dash display / loggers.
Please Note:
MXG / MXS / MXL (Strada and Pista) / MXL2 / EVO5 / MXm etc harnesses are fitted with 719 connections. To extend the length between your dash display / logger and the analogue sensor, please use the 719-719 extension lead which is available in various lengths. For most installations you will need one of these leads.
AiM Technologies are committed to supplying, professional engineers quality Motorsport products. Our cables and accessories are well-engineered and  designed for demanding Motorsport applications and the demands that racing puts on components. Which makes ours amongst the best in the market place today.
Unlock your potential
    AiM Water / Oil PT100 Thermal Resistor M10 Thread
    • Temperature Range: 0/150°C
    • Cable Sensor Length: 250mm
    The drawing below shows the sensor dimensions on the left and the inline water/oil fitting dimensions on the right in millimetres.
    The sensor end has a 4 pin male 719 Binder connector that features a 2k 1% resistor between pins 1 and 4. Below shows the connector pinout solder termination view as well as the connection table.
