AiM Water / Oil Thermal Resistor
Our water / oil PT100 thermo resistor sensor can measure and sample temperature.
Key Features:
Measure Water / Oil Temperature |
The thermo resistor must be placed in the cooling system / oil sump. Install the sensor away from heat and electromagnetic interference sources, such as RPM cable or lap timer receiver cables. Please Note: MXG / MXS / MXL (Strada and Pista) / MXL2 / EVO5 / MXm etc harnesses are fitted with 719 connections. To extend the length between your dash display / logger and the analogue sensor, please use the 719-719 extension lead which is available in various lengths from 0.5 - 3 metres. For most installations you will need one of these leads. EVO4 / EVO4S logger / Channel Expansion are fitted with 712 connections and require a 712-719 extension lead to connect these sensors. |
AiM Technologies are committed to supplying, professional engineers quality Motorsport products. Our cables and accessories are well-engineered and designed for demanding Motorsport applications and the demands that racing puts on components. Which makes ours amongst the best in the market place today. |
Unlock your potential |
AiM Water & Oil PT100 Thermal Resistor M5 Thread
- Temperature Range: 0/150°C
- Cable Sensor Length: 250mm
The drawing below shows the sensors dimensions on the left and the inline water / oil fitting dimensions on the right in mm.
Below is a drawing to show the connector pinout solder termination as well as the connection table.
