AiM Water / Oil PT100 Thermo Resistor M5 Thread Motorcycle
£65
AiM Water / Oil Thermal Resistor  Our water / oil PT100 thermo resistor sensor can measure and sample...
Our water / oil PT100 thermo resistor sensor can measure and sample temperature.
Key Features:
  • Temperature Sensor
  • 4 pin
  • 719 Plug Male
  • M5 Thread
Measure Water / Oil Temperature
The thermo resistor must be placed in the cooling system / oil sump.
Install the sensor away from heat and electromagnetic interference sources, such as RPM cable or lap timer receiver cables.
Please Note: MXG / MXS / MXL (Strada and Pista) / MXL2 / EVO5 / MXm etc harnesses are fitted with 719 connections. To extend the length between your dash display / logger and the analogue sensor, please use the 719-719 extension lead which is available in various lengths from 0.5 - 3 metres. For most installations you will need one of these leads.
AiM are committed to supplying, professional engineers quality Motorsport products. Out cables and accessories are well-engineered and designed for demanding Motorsport applications and the demands that racing puts on components and our products are the best on the market today.
    AiM Water & Oil PT100 Thermal Resistor M5 Thread
    • Temperature Range: 0/150°C
    • Cable Sensor Length: 250mm
    The drawing below shows the sensors dimensions on the left and the inline water / oil fitting dimensions on the right in mm.
    Below is a drawing to show the connector pinout solder termination as well as the connection table.
