Aim Water Oil Temp M10 Mignon Plug Motorcycle – AimShop.com
SKU: S-T-M10-M-BIKE
Availability: 50 in stock
£78.00
QTY:
Trust Badge
Aim Water Oil Temp M10 Mignon Plug MotorcycleThe Water Oil temperature is important to log as, you need to see how hot the engine gets. You need to keep it at optimum temperature. To prevent any damage what can happen if it overheats.
