AiM Water / Oil Temp M10 Type K Thermocouple Bike
£65
AiM M10 K Type Thermocouple Sensor AiM Thermocouple sensor M10 Type K. Key Features: Water / Oil 2...
Key Features:
  • Water / Oil
  • 2 pin mignon male
  • Free race studio 3 download
  • M10 Type K
Monitor Temperature
Our AiM device can measure the water temperature , thermocouple placed in the cooling system.
All AiM thermocouples are K Type sensors.
The thermocouple has to be placed in the cooling system. Install the sensor far from heat and electromagnetic interference sources, like RPM cable or lap receiver cables.
Please Note: MXG / MXS / MXL (Strada and Pista) / MXL2 / EVO5 / MXm etc harnesses are fitted with 719 connections. To extend the length between your dash display / logger and the analogue sensor, please use the 719-719 extension lead which is available in various lengths from 0.5 - 3 metres. For most installations you will need one of these leads.
    • Temperature working range: 0-150C (32-302F)
    • Cable Type: Compensated
    The drawing below shows the thermocouple dimensions, on top and the optional water fitting dimensions on the bottom in mm.
    The thermocouple has 2 pins Mignon connector. The image below shows the connector on the left and the connection table on the right.
