AiM M10 Type K Thermocouple Sensor.
AiM Thermocouple sensor M10 Type K.
Key Features:
All AiM thermocouples are K Type sensors. |
The thermocouple has to be placed in the cooling system. Install the sensor far from heat and electromagnetic interference sources, like RPM cable or lap receiver cables. |
Please Note: MXG / MXS / MXL (Strada and Pista) / MXL2 / EVO5 / MXm etc harnesses are fitted with 719 connections. To extend the length between your dash display / logger and the analogue sensor, please use the 719-719 extension lead which is available in various lengths from 0.5 - 3 metres. For most installations you will need one of these leads. EVO4 / EVO4S logger / Channel Expansion are fitted with 712 connections and require a 712-719 extension lead to connect these sensors. |
AiM Technologies are committed to supplying, professional engineers quality Motorsport products. Our cables and accessories are well-engineered and designed for demanding Motorsport applications and the demands that racing puts on components. Which makes ours amongst the best in the market place today. |
Unlock your potential |
AiM Water / Oil Temp M10 Type K Thermocouple Car
- Temperature working range: 0-150C (32-302F)
- Cable Type: Compensated
The drawing below shows the thermocouple dimensions, on top and the optional water fitting dimensions on the bottom in mm.
The thermocouple has 2 pins Mignon connector. The image below shows the connector on the left and the connection table on the right.
