FREE Shipping NEXT DAY Delivery Call +44 (0)1782 393843 Shop now, pay later
AiM Water / Oil Temp M10 Type K Thermocouple for Kart
£65.00
AiM K Type Thermocouple Sensor.
AiM Thermocouple sensor M10 Type K.
Key Features:
  • Water / Oil
  • 2 pin mignon male
  • Free race studio 3 download
Monitor Temperature
Our AiM device can measure the water temperature , thermocouple placed in the cooling system.
All AiM thermocouples are K Type sensors.
The thermocouple has to be placed in the cooling system. Install the sensor far from heat and electromagnetic interference sources, like RPM cable or lap receiver cables.
Please Note: MXG / MXS / MXL (Strada and Pista) / MXL2 / EVO5 / MXm etc harnesses are fitted with 719 connections. To extend the length between your dash display / logger and the analogue sensor, please use the 719-719 extension lead which is available in various lengths from 0.5 - 3 metres. For most installations you will need one of these leads.
AiM Technologies are committed to supplying, professional engineers quality Motorsport products. Our cables and accessories are well-engineered and  designed for demanding Motorsport applications and the demands that racing puts on components. Which makes ours amongst the best in the market place today.
Unlock your potential
    • Temperature working range: 0-150C (32-302F)
    • Cable Type: Compensated
    The drawing below shows the thermocouple dimensions, on top and the optional water fitting dimensions on the bottom in mm.
    The thermocouple has 2 pins Mignon connector. The image below shows the connector on the left and the connection table on the right.
