Aim Water Oil Temp M5 Mignon Plug Motorcycle – Aim Shop - Motorsport Data Loggers, Displays and Laptimers
SKU: S-T-M5-M
Availability: 49 in stock
£78.00
QTY:
Trust Badge
Aim Water Oil Temp M5 Mignon Plug Motorcycle. The Water Oil temperature is important to log as, you need to see how hot the engine gets. You need to keep it at optimum temperature. To prevent any damage what can happen if it overheats.
