FREE Shipping NEXT DAY Delivery Call +44 (0)1782 393843 Shop now, pay later
AiM Water / Oil Thermo Resistor 1/8th NPT Thread Motocross
£65.00
MotAiM Water / Oil Thermoresistor 1/8th NPT Thread
Our water / oil thermo resistor sensor can measure and sample temperature.
Key Features:
  • Temperature Sensor
  • 4 pin
  • Free race studio 3 download
  • 1/8" NPT Thread
Measure Water / Oil Temperature
The thermo resistor should be placed in the pipe that goes from the radiator to the cylinder.
Install the sensor away from heat and electromagnetic interference sources, such as RPM cable or lap timer receiver cables.
Please Note: MXG / MXS / MXL (Strada and Pista) / MXL2 / EVO5 / MXm etc harnesses are fitted with 719 connections. To extend the length between your dash display / logger and the analogue sensor, please use the 719-719 extension lead which is available in various lengths from 0.5 - 3 metres. For most installations you will need one of these leads.
AiM Technologies are committed to supplying, professional engineers quality Motorsport products. Our cables and accessories are well-engineered and  designed for demanding Motorsport applications and the demands that racing puts on components. Which makes ours amongst the best in the market place today.
Unlock your potential
    AiM Water / Oil Thermal Resistor  1/8th NPT Thread
    • Temperature Range: 0/150°C
    • Cable Sensor Length: 25cm
    The image below shows the thermo resistor dimensions in mm.
    The thermo resistor ends with a 4 pin Binder 719 male connector. The image below shows the connector pinout from termination side. Resistor is mounted between 1 and pin 4.
