Aprilia RSV4 RR/RF, 1100, Tuono V4 RR/ Factory ECU EVO4S Plug & Play Cable with 7 Pin Male 712 Connector
£50
Aprilia RSV4, Tuono V4 ECU EVO4S Plug & Play Cable. The Aprilia ECU Interface cable is a specific...
The Aprilia ECU Interface cable is a specific cable which allows easy installation and connecting to an AiM EVO4S data logger to the bike ECU.
Key Features:
  • Plug & Play interface cable
  • Simple Wiring
  • Receive Data
  • 7 Pin
  • 712 Male Connector
  • Free race studio 3 download
Aprilia ECU EVO4S Plug & Play Cable Available For:
  • RSV4 RR/RF - from 2017
  • RSV4 1100 - from 2019
  • Tuono V4 RR/Factory - from 2017
Examples of Protocols Below
RPM, Throttle position, Engaged gear, Neutral sensor, Front wheel speed, Rear wheel speed, Engine coolant temperature, Selected map, Engine check, Manual throttle, Intake air temperature, Yawing rate, Rolling rate, Horizontal accelerometer, Vertical accelerometer, Longitudinal acceleration, Traction control intervention, Clutch switch, Side stand, Front brake, Rear brake, Oil pressure switch.
Please Note: For this model/year AiM recommends not to remove the stock dash. Doing so will disable some of the bike functions or safety controls. AiM will not be held responsible for any consequences that may result from the replacement of the original instrumentation cluster.
Not Enough Check Out Our Solo 2 DL & SmartyCams
    • Aprilia RSV4 RR/RF, 1100, Tuono V4 RR/ Factory ECU EVO4S Plug & Play Cable with 7 Pin Male 712 Connector
