Aprilia RSV4, Tuono V4 Solo 2 DL Plug & Play Cable
The Aprilia ECU Interface cable is a specific cable which allows easy installation and connecting to an AiM Solo 2 DL lap timer or EVO4S data logger.
Key Features:
Please Note: If you are unsure this cable will fit your Bike don't hesitate to contact our team. Either by email, phone or our online chat. |
Please Note: For this model/year AiM recommends not to remove the stock dash. Doing so will disable some of the bike functions or safety controls. AiM will not be held responsible for any consequences that may result from the replacement of the original instrumentation cluster. |
Not Enough Check Out Our Solo 2 DL & SmartyCams |
Unlock your potential |
Aprilia RSV4 RR/RF, 1100, Tuono V4 RR/ Factory Solo 2 DL Plug & Play Cable with 7 Pin Male 712 Connector
- Aprilia RSV4 RR/RF, 1100, Tuono V4 RR/ Factory Solo 2 DL Plug & Play Cable with 7 Pin Male 712 Connector
