BMW S1000 RR HP4 ECU EVO4S Plug & Play Cable
£50
BMW S1000 RR HP4 EVO4S ECU Plug & Play Cable. The BMW ECU Interface cable is a specific...
The BMW ECU Interface cable is a specific cable which allows easy installation and connection of the AiM EVO4S data logger to the bike ECU.
Key Features:
  • ECU Interface Cable
  • Simple Wiring
  • Receive Data
  • Free Race Studio 3 Download
BMW ECU Plug & Play Cable Available For:
  • BMW S1000RR - 2009-2014
  • BMW S1000RR - 2015-2019
  • BMW S1000RR HP4 - 2013-2014
Examples of Protocols Below
RPM, Throttle position, Engaged gear, Neutral sensor, Front wheel speed, Rear wheel speed, Engine coolant temperature, Selected map, Engine check, Manual throttle, Intake air temperature, Yawing rate, Rolling rate, Horizontal accelerometer, Vertical accelerometer, Longitudinal acceleration, Traction control intervention, Clutch switch, Side stand, Front brake, Rear brake, Oil pressure switch.
Please Note: For this model/year AiM recommends not to remove the stock dash. Doing so will disable some of the bike functions or safety controls. AiM will not be held responsible for any consequences that may result from the replacement of the original instrumentation cluster.
Not Enough Check Out Our Solo 2 DL & SmartyCams
AiM Solo 2 DL Product Video
    • BMW S1000 RR, HP4 ECU EVO4S Plug & Play Cable
