NEXT DAY DELIVERY
on orders before 3pm
FINANCE AVAILABLE
on selected products
FIRST-CLASS SUPPORT
Yamaha R6 2004-2005 Solo 2 DL Cable and Bracket
£85
The Yamaha R6 2004-2005, Solo 2 DL Cable and Bracket makes it easy to connect the Aim Solo 2 DL to your bike engine ECU.
Cable:
Part number     V02569200
On Race Studio 2 select:
ECU Manufacturer:     YAMAHA
ECU Model:     BIKE_R6_04_05
Technical drawing:
Bracket:
Part number     X46KSYR16
The bracket can be used with Solo and SoloDL.
In the box: 1 bracket, 2 distance pieces, 2 M6 self-locking nut, 4 M6 washers, 2 M4 self locking nuts, 2 M4 washers, 2 4x10 Allen screws with countersunk head, 2 6x60 pan head Allen screws.
Download the installation manual
User manual
