AiM Solo 2 DL + SmartyCam Motorcycle Plug & Play Track Day Kit
£1,295
Predictive Lap Timer & Data Logger  AiM Solo 2 DL, the most precise and simple way to get lap times,...
AiM Solo 2 DL, the most precise and simple way to get lap times, with ECU data and overlay it all with your SmartyCam video as well.
Key Features:
  • Connectable to every ECU for receiving and recording data
  • 10 configurable RGB LEDs for simple Time +/- reference
  • Rechargeable internal battery
  • Multiple use modes: speed, times & performance
  • WIFI with security for downloading data
  • Internal 4 GB memory
  • Automatic GPS lap timer
  • Simple new open or closed track creation
  • Configurable delta and split times
  • Multiple & configurable backlit graphical display
  • Database, with more than 4,000 tracks worldwide
  • Freely configurable display
  • Automatic track recognition and start / stop
  • Free Race Studio 3 Download
Plug and Play Kits available for:
 The Solo 2 DL Plug & Play
Aim Solo 2 DL Motorcycle Video Data Logger Track Day Kit, is a powerful data recording combination of the Solo 2 DL and SmartyCam GP HD Bullet Camera.
Solo 2 DL connects to your ECU with a plug and play cable to provide you with ECU and GPS data. SmartyCam GP HD records your on board video and audio.
AiM SmartyCam GP HD has been designed for Motorsport to enable you to produce great videos that include all the information you need to improve your performance.
Solo 2 DL ECU Connection
Connecting to over 1,000+ ECUs, we are sure it will work for you.
You can connect your Solo 2 DL to the ECU with a simple ODB11 plug or hardwired in providing you with all your Motorcycle  information and power with just one cable.
Incase your ECU protocol is not in the database, no problem: with our ECU Driver Builder you can build your own its free in Race Studio 3 configuration Software and you will be able to create your protocol on your own.
Solo 2 DL is great because once you have downloaded your entire session on to your PC you can split the recording into individual laps with a simple click. You can simultaneously watch two of them and check where you were faster or slower.
Multiple Configurations Management
Solo 2 DL can receive up to 10 configurations at one time allowing you to switch among them through keys.
The Most Precise and Easy Way to get Lap Times
Aim Solo 2 DL is the most precise GPS Lap Timer there is. With the ability to show you your lap delta as you drive...receiving data from two satellite constellations from any where on the globe by using GPS and Glonass, also giving you a significant improvement in data speed and positioning precision.
The power ON requires only a few seconds and lap times calculated with a max 2/100 sec of tolerance.
Solo 2 DL gives instant Speed, Timing, Splits live data and predictive lap times.
Solo 2 DL screen can be back lit in one of seven available colours.
The AiM Solo 2 DL has 10 configurable RGB LEDs, and will give you a clear and fast indication of the comparison with your last lap. Predictive page: shows the predicted current lap time in the format you set.
+/- in relation to the Reference Lap Predicted Lap Time.
You can custom build the layout of the display, to show the information you choose on 4 reconfigurable pages, your data shown in your way, see an example below.
Solo 2 DL Data Recall Modes
Solo 2 DL can manage two types of data or races:
In each of these configurations, Solo 2 DL gives the complete information during the test with the data ready to view on the Solo 2DL or Race Studio Analysis software immediately after each race or test session.
Data Recall on Screen Data
At the end of your test you can quickly review all the key information on your display, RPM, Temps Times ECT.
SmartyCam HD or HD GP Connection
The perfect connection to get all your data from the ECU, merge them with the GPS information and transmit everything to the SmartyCam GP HD then watch the graphical overlay in the video.
The SmartyCam has been engineered to withstand the extreme working conditions typical of all Motorsport.
Unlock your potential with SmartyCam and Race Studio 3
Wi-Fi Communication with the PC
With wifi connectivity you can transfer your data securely and quickly to your laptop or computer without cables.
Solo 2 DL New Track Creation and our Track Database
Solo 2
 DL allows you to simply create a new temporary or permanent track layout weather its a point to point run for rallying, or a closed loop track it can simply be aded to the Solo 2 DL and PC database.
Simply put, if there is no track already, the Solo 2 DL will create a new one...
With over 4000 tracks pre-loaded from around the world. As soon as its switched on the Solo 2 DL identifies its position then once you start to drive it automatically recognises the start line coordinates of the track and will start sampling lap times every time you go past.
If the tracks not loaded in the database
Solo 2 DL will switch to learning mode automatically and will understand the characteristics of the track and give you your lap time.
Our mission is to help educate you and enable you to get the most out of your AiM data equipment… whether you are new to racing or a seasoned professional there is always something new to learn.
AiM Solo 2 DL Product Video
    AiM Solo 2 DL
    • Display: Graphical
    • Display resolution:238x99 pixels
    • Display pages: Up to 8 freely configurable
    • Back light: 7 configurable RGB colours
    • Shift lights/alarm LED's :10 configurable RGB LED's
    • Integrated track database:Yes
    • Inertial platform: Internal 3 axis ±5G accelerometer + 3 axis gyro + 3 axis magnetometer
    • Wi-Fi connection: Yes
    • GPS: 10 Hz External power:12 V
    • Memory: 4 GB
    • Pushbuttons: Metallic
    • Dimensions: 98.0x73.7x30.2 mm
    • Weight: 240 g, battery included
    • ECU Connection: CAN,RS232 or K-Line to 1,000+ industry leading ECUs
    • Multiple Configuration Management: Yes
    AiM SmartyCam
    •  Video format                        H.264 1280x720 pixels @ 30 fps
    •  Display resolution                2.4" 240x320 pixels
    •  Lens                                      Telecentric with 6 elements
    •  Field of view                         67° or 84° or 120°
    •  Internal battery                    Rechargeable Lithium battery - 1,500 mAh
    • Battery charge                      700 mAh 12 V
    • Internal battery duration      60 - 70 min of recording
    • External power                      9-15 V
    •  Supported SD card              Up to 128 GB
    •  Memory capability               1.5 GB (1 hour low quality recording)
    •                                                2 GB (1 hour medium quality recording)
    •                                                4 GB (1 hour high quality recording)
    •  Accelerometer                     Three-axial ± 5G
    • Usage temperatures             -10°C/+60°C
    •  Auto Power ON                     Yes, if connected to an AiM logger
    •  Auto Power OFF                    Yes
    •  Auto Start/Stop Recording   Yes
    •  Body                                        Anodized Aluminum
    •  Dimensions                            Main unit 104.6 x 79.6 x 26.6 mm
    •                                                  Bullet camera 24 diam x 48.2 mm
    • Connectors                            3 Binder 712 female connectors
    •                                                 + 1SMA female connector
    • Bullet cable length                 2.0 m
    • Weight                                   Main unit 320 g, Bullet camera 45 g
    • Waterproof                            Yes
    AiM Solo 2 DL 360° Product View
    • Aim Solo DL 2 DL Motorcycle Lap Timer
    • Power cable with AC adapter
    • Mounting bracket with screws,
    • User manual,
    • Software installation CD,
    • Aim sticker
    • SmartyCam GP HD Rev .2.2 Bullet-Cam
    • 2m Cable
    • UK Adaptor
    • Camera Bracket
    • Power Lead
