4 Key CAN Switch Keypad.
Our CAN bus keypads integrate with your on-board vehicle electronic systems.
Features:
Remote Button Interface KeypadOur remote button interface keypad will enable you to have your very own selection of buttons at your fingertips. With a large range of laser etched inserts you can customise your keypad the way that's right for you, Lights, Heating & Fans, Parking the list is endless. Please Note: The keypad does not come with any inserts you can choose from the large range we have available from the optional extras section at the top of the page. Also the lights showing on the keypads are for visual effect and to show you how the keypad could look.
Built in LEDs |
15mm Etched Inserts |
The keypad is CAN bus compatible so it is able to dialogue with on board systems. The laser etched icons / inserts have been designed to fit our remote button interface keypads, The inserts are 15mm in size and laser etched to a high standard, so you can clearly see the icons on your keypad during the day and night.
Unlock your potential |
Our mission is to help enable you to get the most out of your AiM data equipment… whether you are new to racing or a seasoned professional, there is always something new to learn. |
CAN Based Remote 4 Button Interface Keypad.
- Supply Voltage: 12-24Vdc Nominal (8-32VDC)
- Standby Current: <50mA
- Communicational BUS: RS485, CANopen J1939
- Connector: Deutsch DT04-4P
- Switch Life: 3 million operations
- Mounting Studs: 10-32 Steel
- Keypad: Silicone rubber with polyurethane hardcoat
- PC Board: 1.6mm thick, Nema Grade FR-4, double clad with 1 oz copper
- Operating Temperature: -40°C to +70°C
- Storage Temperature: -40°C to +85°C
- Thermal Shock: -40°C to +85°C
- UV Protection: UVB 400 hours
- Salt Spray: Per ASTMB117
- Chemical Resistance: Dirt, Engine Cleaner, Isopropyl Alcohol, Suntan Lotion, Multi-purpose cleaner, Orange Citrus Cleaner, Muriatic Acid.
- Ingress Protection Rating: IP67 / IP69K
- Weight: 110 gr (inserts excluded)
K# Mom - A 1 is returned while the key is pressed.
K# Tog - A 1 is returned on first press and remains until a second press.
K# 012 - A 1 is returned on first press and remains until, A 2 is returned on next press and A 0 is returned on another press before restarting the cycle.
K# 0123 - A 1 is retuned on first press, A 2 is returned after the next press, A 4 is returned after the next press, A 0 is returned after another press, and the cycle repeats.
- CAN bus compatible keypad - No inserts
