AiM MXS 5" TFT World SSP600 FIM Kit
The MXS 1.2 TFT is a dash logger designed to acquire and display data coming from your ECU.
Key Features:
AiM has designed a specific connection for the World SSP 600 bikes. The 37 pin Deutsch harness can read transmitted data from the ECU via CAN, and power up the system.
This Kit is compatible with:
World SSP 600 bikes (with MecTronik) - MKE7 ECU) Please Note: If you are unsure this cable will fit your Bike don't hesitate to contact our team. Either by email, phone or our online chat. Please see the technical sheet for the information on the Sumitomo connection kit, which also includes the information regarding the pinout and Race Studio 3 configuration. It shows a huge amount of protocols, Channel Name & Function for Mectronik WSS 2019 V5.
AiM MXS 1.2 Dash Logger
The AiM MXS 1.2 5" display is fully configurable and easy to use. The dash logger has been designed to acquire and display data coming from the ECU, the internal accelerometer and gyro, as well as the GPS Module included in the kit, analog and digital inputs and predefined math channels. Performance and data acquired can also be incremented adding up to eight expansion modules. The 5" display has been designed for small cockpit installation.
CAN OutputThe CAN output can send messages directly to an existing CAN network which will improve the range of your car's control possibilities. |
The MXS has an integrated 10 LED shift light. Chose from a host of advanced multi coloured RGB shift light patterns that can be customised to your liking, also for each unique gear when required. |
Unlock your potential
MXS 1.2 TFT Digital Display and Data Logger
- Display: 5" TFT
- Contrast: 6000:1
- Ambient Light Sensor: Yes
- CAN Connections: 3
- ECU Compatibility: + 1000 industry leading ECUs
- Expansion CAN Connection: GPS, Channel expansion, Thermocouple expansions, Lambda controller, SmartyCam HD
- Analog inputs: 8 fully configurable, max 1000 Hz each
- Digital inputs: 4 speed inputs, lap signal, coil RPM input
- Digital outputs: 2 (1 A max each)
- Second CAN: Yes
- Wi-Fi Connection: Yes
- Accelerometer: Internal Three-axial + 5G + Three-axial Gyroscope
- Internal memory: 4 GB
- Body: Anodised Aluminium
- Connectors: 2 motorsport connectors = 1 Binder connector
- Power consumption: 400 mA
- Dimensions: 169.4x97x23mm
- Weight: 530g
MXS 1.2 TFT Digital Display & Dash Logger
- MXS 1.2
- 37 pins harness
- GPS Module
Connection Kit
- x 1 6 pin male sumitomo connector
- x 4 sumitomo connector male pins
- x 4 rubber wire seals
- x 2 dummy plugs
