AiM Motorcycle Data Hub 2X CAN Connection Multiplier
£50.00
AiM 2X Data Hub
AiM Data Hub 2X hub connection multiplier works as an interface between AiM loggers and peripheral sensors.
Key Features:
The AiM Two Hub Data LoggerThe data hub 2x CAN connection multiplier is used for the acquisition of all the essential data you need to evaluate your performance. The data hub is an external expansion module that allows you to increase the range of data available for analysis. |
This implies the presence of a great number of cables but the Data Hub takes all the information you need sent to the logger with just one cable, minimising wires overall. More Data Hubs can be connected in sequence in order to increase the number of peripherals which can be connected. |
Connection Example |
- Dimensions: 70x30x23.5mm
- CAN cable length: 40cm
- Source Cable Length: 165cm
- Weight: 86g
