Car Fuel Level Sender With Aim Plug 719 Cable
£189
The Car Fuel Level Sender (719 plug) records the fuel level, allowing you to determine how much fuel...
The Car Fuel Level Sender (719 plug) records the fuel level, allowing you to determine how much fuel you need for a session or race.
The Car Fuel Level Sender will come with bolts, washers and Gasket set and a 719 binder cable.
